solar collector heating
Andrew_21
Member Posts: 1
Hello: I need some help
I have 4 solar collector that I just installed. I also have a coil for my woodstove installed. I am currently supplementing my heating with a propane fired hot water tank. I would like to switch over to a on demand heater and isolate my radiant floor heating as a closed loop as well as the solar collectors are a closed loop. Is it recomended to run a on demand heater in a closed loop and use heat transfer plates to suppliment my radiant floor and potable water?
- 167 Indoor-Air Quality
