looking for instantaneuos
Ron Huber_2
Member Posts: 127
Need an instantaneous that works like the Bosch/Aquastar solar model,but without the standing pilot, and the ability to direct vent like the Rinnai. The solar model is/was the only unit I could find that can modulate based on the incoming temps from the solar tank, had one here at my own house and if worked great. Now I have a few solar customers who are looking for the same set up, but need direct vent.
Noritz N084MC-DV
This might fit your bill. Sold about 6 of these in the past 2 months no issues - as is the case with the entire Noritz line.
I sold one of these for use with a ground source heat pump super heater. we controlled the inlet water with a tempering valve so we could have a sufficient delta t to fire it and relatively constant inlet temperature. I haven't heard about any issues yet. See attached drawing.
Open with Adobe Acrobat its a pdf.
My $.02
Glenn0 -
The Rinnai
will modulate based upon flow and temps. It will work fine with the solar system0
