bypass differential
Yes it does, I have used many,, just don`t loose the gasket or you`ll be ticked.<BR><BR>Dave
taco bypass diff. valve ?
I am going to install a multiple zone hydronic heat system using zone valves. I just recieved the Taco differential bypass valve and noticed that there is a union nut on one of the ports. Is there suppose to be a spud simmilar to a radiator valve or steam trap that was not packaged with the valve? There was a gasket included but nothing else. Does this nut just thread onto a 3/4 IPS thread?
Thanks,
thanks
thanks, I just wanted to be sure!0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
