why did my cooktop screws seize, when boiler screws don't
Plumb Bob
Member Posts: 97
Homeowner here.
The screws in the burner bases of my cooktop turned black soon after installation, and after 4 years they seized. The heads stripped from attempting to unscrew them, and I had to pay through the nose to get them extracted so I could replace the spark rods. Repairman tells me this is a quite common problem, in ovens as well, it keeps them in business.
But this doesn't happen in my Munchkin boiler. The nut that's holding the back insulation plate, for example, is right next to the burner and must get quite hot, but it is pristine (no discoloration, no problem loosening or retightening it). There are other screws (e.g. in the boiler front cover) that must also get very hot but are in good condition.
What's the difference? Do boilers use a special alloy, or is it something else? I know you can't use stainless because it seizes easily.
Just trying to figure out if there is a way I could avoid having the same cooktop problem in future.
Those screws holding
your oven igniters or any others should be left slightly loose. They also need to be sprayed with WD40 before attempting to remove. Other screws on ranges many times are shipping screws and are supposed to be removed at time of installation.
Ranges have much more moisture and combustion issues to deal with than boilers or furnaces. Most are not venting into a mechanical vent and simply vent into the kitchen area hence poor drafting and the acidic content will corrode metals it comes in contact with.0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
