Weil McClain Drain Valve Replacement
Jim_157
Jim_157 Member Posts: 1
Hi All,
I have a Weil McClain boiler that has a clogged drain valve which has me a bit worried. I'm unable to drain off the sediment that typically accumulates. I'm in need of a boiler professional that can replace the valve and give he boiler a good looking over. I have tried the "Find a Professional" feature and have come up empty. Can anyone recommend a good, honest company in the southeast michigan area, more specifically, Berkley area that might be able to help?
Thanks much, Jim
