Plasma cutter?
oil246gas
oil246gas Member Posts: 12
do you own a plasma cutter? - if not i would use a grinder with cutting wheels for stainless -i use the wheels all the time they work great --just make sure you have safety gear on - i've never had a wheel break on me but i don't think i'd want to
  • Timco
    Timco Member Posts: 3,040
    I have a very old indirect tank to remove (about 8' long and 3-4' in diameter) and the last time I took one out I used oxy / acetelyne. Problem is I do not have access to an exterior door for ventilation this time and last time the oxy / act had a tough time with the 1-2" of rust & build-up on the inside of the tank...even at 40/10 with a huge tip. What would be best? Electric grinder w/ cut off blade? I hate to go gas-powered as I have no fresh air or way to ventilate. Plasma cutter?
    Thanks guys, Tim
  • Jack
    Jack Member Posts: 1,049
    Both methods will work
    The plasma cutter will need significant amount of compressed air. Do you have a compressor available. If it isn't large enough you will wait and wait for it to catch up. As well, if there are a lot of deposits internal to the tank you will jsut get a lot of blow-back unless you have a powerful plasma machine.
    I'd start with a small angle grinder. You can get the thin cut-off wheels or go with the thicker wheels. If you cock one of the cut-off wheels it can come apart. I'd get my sawzall into the mix also.
  • tim smith
    tim smith Member Posts: 2,807
    Steel or stainless
    Stainless indirect normally fairly thin steel, sawzall works just fine. If it is steel, samething or if you use plasma or torch, we take a 5# sledge along the cut line as we go and hit it to break free the sludge/rust build up. Plasma will blow back just like a torch I found so you need to break the stuff up a bit.
