load mectron3
val_3
val_3 Member Posts: 3
i have a two pipe oil feed to my riello burner on my heating system that works fine but it tees off after the filter and feeds a mectron3 riello hot water heater this burner is making a loud pitch screeching sound when the heater kicks on.filter and nozzle changed ,oil pumped changed also checked for leaks on supply and return lines.any ideas of what to check next.thanks
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    Yep....
    Check out a single line from the tank and a tigerloop plus for each appliance. Chris
