Heat effect
Chuck_17
Chuck_17 Member Posts: 148
I thought I saw "heat effect" for baseboard and radiant panel ratings discussed somewhere. Could someone point my to s discussion of this?
  • Brad White_198
    Brad White_198 Member Posts: 72
    Nothing specific but
    the heat effect (normally about 15 percent).
    It is allowed as a credit for radiation only when provided along the perimeter of a space along the exterior wall (as opposed to on an interior wall even if of the same BTU rating).
    The concept is that the film of warm air/thermal flux along the exterior, specifically between you and the great outdoors, is a barrier to radiant loss from your body. In effect it "cheats" your body into thinking that it is warmer by raising the mean radiant temperature of your surroundings.
    I=B=R, now the Hydronics Institute, first conceived of that years ago.
