Tigerloop Question
I have a Tigerloop that appears to be malfunctioning. We
have only about three quarters of an inch of oil in the
lower chamber and the rest is foam. There is plenty of oil,
new oil line and pump and all fittings are tight. Is it
possible that the Tigerloop is not venting properly?
Is it possible that the air is not venting and creating
pressure in the chamber which is not allowing an adequate
amount of oil to enter? If I jump the FF terminal on the
primary control and allow the pump to run for a while I
will get the burner to operate. It will shut down on high
limit and not re-start. Does anyone have advice on this
matter.
