Steam main vents
Steamhead (in transit)
Member Posts: 6,688
and if you can't get the drill in position to drill the hole in the top, you can drill in the side and elbow up. Leave a bit of pitch in the short horizontal pipe, towards the main.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Steam main vents
I recall a few years back that Steamhead gave some great advice on tuning a one pipe system for fuel savings. He mentioned, I think, burning a hole 15" from the end of an unvented main and welding on a fitting for a nipple and air vent. It would be greatly appreciated if anyone has info on this. I think the fitting was called a "weld-o-let"??? Not sure what it is called and where to get them.
Thanks again,
Sam0 -
We only have that done
on our BIG projects, like the one in our Find a Professional ad. Click the link below to see it.
For the usual residential system, drilling and tapping works fine.
Thanks for the info, cool vent setup.0 -
Mains with No vents
So to follow-up on what you said, is it ok to drill and tap the main vent directly into the main line it's self (15" back from the end)?0 -
One more question
How large should the tap be? would 1/8, 1/4, 3/4???
Boston0
- 167 Indoor-Air Quality
