OLD copper tank
Joe Billow_6
Member Posts: 69
Make it shiny again and use it for a buffer. That would look cool.
Copper tank
I have an old copper tank that I stripping the water heater of its shell. I believe the tank is in good shape. I would like to use it in some way. Has anyone done something similar? I was thinking to add it for some storage or maybe wrapping some pex around it and insulating the take. I would use a return line before going back to my condensing boiler.
It is a 20 gallon tank. There are two 3/4" i.p.s. top connections and two 3/4" lower connections. I am missing the dip tube that was in the cold feed. I hope to replace that. I will clean and test the tank first.0 -
Gallant effort Ted,
just be sure to hydrostatically test it(with water), NOT compressed-air, saw a guy do that once and he broke his leg in 3 places when it exploded!
I tried wrapping a 30Gal tank once in pex from my boiler as a pre-warmer, didn`t do much for me, perhaps you`ll have better results.
Good Luck, and be careful!
Dave0 -
I'm Thinking
Home Still.....as in refreshments.
Gordy0 -
Copper tank
Sounds like you tried doing the same thing Dave.0 -
Ditto Ted,
my system was soooo oversized & screwy I abandoned that idea for a mod con & indirect.
Dave0 -
I'm Thinking
$3.10 a pound scrap0 -
I'm thinking...
DITTO!
I'll never forget the time I was demo-ing an old mechanical room and under the insulation the 4x8 duct was COPPER! Even at 35 cents a pound I got over $300 for the scrap. I'd like to find some more of that today!0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
