Recepie for light weigh concrete
bobbyg_16
Member Posts: 11
http://www.pmmag.com/Articles/Column/296a9ac235fc7010VgnVCM100000f932a8c0____
I actually found it in "Hydronic Radiant Heating - a practical guide for the nonengineer installer by Dan Holohan" but it does reference John Siegenthaler.
Both their books are highly recommended.
Here it is:
makes 1-cubic yard or 3,000 psi (strength at 28 days)
517 lbs. type 1 portland cement
1,630 lbs. concrete sand
1,485 lbs. #1A (1/4" maximum) peastone
4.14 ounces air entraining agent
15.5 ounces Hycol (a water reducing agent)
1.5 lbs. fiber mesh
51.7 ounces superlasticizer (WRDA-19)
about 20 gallons water
Here it is:
1.5 lbs. fiber mesh
Recepie for light weight concrete
Help,
I used to have a recepie for light weight concrete for radiant heat, but I can't find it. Does anyone have a usable recepie. "not Gyp" this is for wet areas.
Dave0 -
Siegenthaler has one.
John Siegenthaler published a recipe in his "Modern Hydronic Heating" book, it was called the "Youker mix". You might google it. I can e-mail you the recipe later tonight if you don't find it.0 -
ask hot rod
Also hot rod might have a few serious suggestions0
