Fitting - What's it called?
You mean something like this?<BR>Most refer to them as vent tees.<BR><BR>Dave
Fitting - what's it called?
Guys - I sure you have covered this many times but I just can't find it.
I have a SlantFin baseboard radiator that I am replacing due to the fact that my youngest son (soon to be late son if he keeps it up) has beat to death with his bicycle. Don't ask. . .
I want to put in a Hygrovent or something similar to help me when I need to bleed any air out of the system. What is the proper name for the brass 90 fitting that I need that I'll use to connect the baseboard radiator and my 3/4" supply line? The old one was what I call a 90 vent elbow (and some other guys call a drain tee). But, that fitting will not accept a 1/8" Hygrovent type valve - it needs to have the female threads to accept it.
Or alternatively, can I use a 1/8" x 1/8" hex bushing to connect the Hygrovent and a new 90 vent elbow?
Am I making any sense? Thanks loads!0 -
It's
called a baseboard tee.A properly designed loop system doesn't need them
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
It's definitely called a baseboard tee yet should be called a band-aid fitting.
As Robert suggested, if you got air in a place where this thing helps you get it out, then you've got a design/installation problem.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
Unless it is a momoflo
If it is a monoflo system it needs a coin vent.
Leo0 -
Might be a Band-Aid today
But was SOP when installing baseboard (in my youth!)0 -
well band aids are good to have when you need them
How many properly designed loops do we see every day? I can only say a few and half of them either Da or I installed the other half seemed to have been mistakes as to the "normal" way of installing. I would prefer to have a vent and not need it then have it the other way around. I would use a coin vent on it though for that January bleed out at midnight.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
