BOILER SIZING QUESTIONS W/RAD PICKS
Smaller supply houses have straight pieces of insulation, and you can use cold water paste for the elbows and fittings.
BOILER SIZE/RAD QUESTIONS W/PICS
Hey Guys,I got some great answers for my prior questions, I would like to go over a couple of things before i go ahead w/a boiler install. I am looking to replace a Burham #405 w/sq ft rating of 350, The house is a single family brick home semi detatched w/a full finished basement, 1st fl, and 2nd floor, and a flat roof. the existing radiation connected to a one pipe system consists of the following.
-Master Bedroom 2nd fl- 1-"American Radiator" 8" wide, 26" high, 5-Tube, 11 sections, at 3.5 sq ft.per section= 38.5 sq ft.
-John's bedroom 2nd floor- 1-American Radiator 8"wide 26"high, 4 tube, 4 sections at 3.5 sq ft per section=14 sq.ft
-Jenns bedroom 2nd floor-1 American Radiator 8"wide, 26" high, 5-tube, 9 sections, at 3.5 sq.ft per section=31.5 sq ft.
2nd fl bathroom, Lokks like a Burnham radiant, 5" deep, 20" high, 13.5 inches wide, 6 sections at 2.25 sq ft. per section=13.5 sq ft.
1st floor Living room- Burnham radiant rad, 5" deep, 20" high, 49.5 wide, 22 sections at 2.25 sq ft. per section= 49.5 sq feet.
1st floor living room Burnham cast iron baseboard, "baseray", 2.5" wide, 10"high, 10.5 feet long at 3.40 sq ft per linear foot = 35.7 sq ft
1st fl bathroom, 1 American Radiator, 20" high, 5" wide, 4 tubes, 6 sections at 2.25 sq ft. per section= 13.5 sq ft
-Kitchen Burnham radiant radiator, 5" deep, 20" high, 22.5" wide 10 sections at 2.25 sq ft per section= 22.5 sq.ft. No picture of this rad
-Pantry- 3 foot piece of Slant fin steam baseboard, 4.1 sq. ft. per section= 12.4 sq ft.
1- Basement ceiling hung radiator, Niagra Radiator Co. single column, 22 sections, 46" long, 15" wide, 2" thick, at 1.5 sq ft. per section = 33 sq ft. Thanks to Steam Head for this info.
Toatal comes to 264.1 sq ft. of radaition, I just want to make sure I will be ok with a Burnham IN4 w/a rating of 271, sq.ft. I will do my best to insulate as much of the heager and mains as I can, the house has had new windows installed and more replacements will coming in the future, the house is of brick construction so I dont think there will be much insulation in the walls, but the house will be re-stuccoed within the next year or so, if that matters any. The basement has been re-framed and isulated properly. Thanks again guys for all your help,0 -
You'll do fine
with the IN4's capacity. No need for a bigger boiler. If you want something a bit more efficient, the Smith G-8 3-section steamer is a good choice, rated at 283 square feet.
Boiler size
Thanks again for your help Steam head,I will look into the Smith G-8 3 section, Any idea where I can purchase some pipe insulation that will fit over 2" steam fittings? el's, 45's, unions, tees, etc? I have been trying searchiing out some web sites but haven't had any luck. thanks again.0 -
Any good insulation supplier
should have them in stock. Some don't sell to the general public, but if that's the case your contractor could get them.
Here's a pic of a G-8 we installed recently- it's a 5-section though. Besides its higher thermal efficiency, you can burn oil in it too if you wish- the factory supports its use with either fuel. A pro could change it over.
Mcmaster Carr
has good pipe insulation and some types insulation for fittings, i will try them out to see how they go, thanks again guys0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
