HW Heater
No problem for a small job. Have used several with no issues. Pipe it correctly and as said in the other post, don't mix heating water with domestic. Some issues may be voiding the warrantee or violating local codes
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=522&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Paul48
    Paul48 Member Posts: 4,469
    HW Heater
    Would there be a problem using a HW heater as a heat source for a radiant hydronic system?
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Potentially a BIG problem--deadly disease (Legionella)--if the very same water is used for domestic consumption.
  • Rich Kontny_3
    Rich Kontny_3 Member Posts: 561
    Dedicate
    What Mike means above is that you need to dedicate that heater as the heat source for the in-floor (hydronics) and not use it as your domestic heater also! The Legionella threat is real as even some on this site have had it(it can be deadly)
    Also you have to take into consideration the in-efficient nature of a gas tank type heater and the high cost of electric if you go that route. Hiring a professional to at least design and lay out of your system would be money well spent. Also find someone who has in-floor and hydronic experience as there are lots of wannabes out there.
    You are asking at the right place though as some of the best frequent this site!
    Rich
  • Paul48
    Efficiency
    Have there been any comparative studies done on the distribution end?In-floor vs. under-floor vs. cast iron baseboard vs. copper fin-tube vs. hot air with the same boiler capable of feeding all?
