multizone thermostat
bob dowling
Member Posts: 1
we are putting in a new hot water boiling, 9 flat panel radiators and under floor radiant hot water with pex and alumiunm plates in kitchen and bath. i know it's crazy but we want to have zone valves for each room, 11 in all. i've installed the radiant runs and i've hung the radiators. my heating professional will connect everything and install the boiler etc. we would like to avoid having a thermostat in each room. i've heard there a programable multizone thermostat that uses one thermostat and sensors in the other zones. do you know about this and can you suggest others thanks in advance bob dowling
Bob....
TRV'S and constant circulation.Or better yet....find a contractor that has access to the UBER, Wilo ECO pump! Chris
(I'm pulling for you Hunt!)0
