Boiler sizing-baseboard system
a .pdf file but somehow it's coming up a .cfm file.I emailed it to you
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=313&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Tim Weaver
    Tim Weaver Member Posts: 49
    Having had a steam system, I am familiar with the boiler sizing process, edr, sq/ft steam, etc. I am purchasing a home that currently has an older W/M atmospheric gas fired boiler, with a 75 gallon indirect that is past its service life. The emitters in the house are all fin type baseboard. In the spring, I want to update the boiler and tank, possibly with a mod/con, and wanted to know how to size same. Is it a matter of just taking the amount of linear feet of baseboard, taking the btu's per foot and multiplying it out? Does a mod/con make sense with low mass emitters like this? Thanks.
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,584
    Go
    to the "Resources" tab above and get the S/F heat loss software.Calculate the heat loss and that will tell you the size boiler you need,the amount of baseboard is irrelevant to the size of the boiler.Read the attached report regarding condensing boilers and baseboard.
  • Supply House Rick
    Supply House Rick Member Posts: 1,399
    Can't open the attachment?
    Please attach again. Thanks
  • Paul Fredricks_9
    Paul Fredricks_9 Member Posts: 315
    It worked for me
    I've found a lot of PDF's come through as CFM's. If your computer won't open it, you need to tell your computer to open a .cfm with powerpoint (or a powerpoint reader) and then it should open.
