Beckett heat manager
Jed_2
Member Posts: 781
Just add the second sensor to teh tankless HWS outlet and plug it in to the control for that sensor.
Anyone installing the Beckett heat manager? pros...cons...they seem to be a good product and the local oil companys are promoting up to 18% savings in fuel...any negitive feedback on them?0 -
For
the price and the 10% savings guarantee,how can you lose?
I have been installing them for a few years now,I have several customers saving up to 20% with it,but most save 10 to 12%0 -
I have one
I don't know if it saved anything or not, but it did expand the differential of my aquastat, and I do like that.0 -
When installing these on a boiler w/ tankless coil it says to attach a sensor to the hot discharge pipe off the coil. Is this the same sensor that you use off the boiler supply piping? They must sell extra sensors separately?0 -
manager
How does the manager work, Does it post purge the boiler after a call for heat or does it fire the boiler depending on the delta T of supply and return piping?0 -
I think
if you want to use a tankless coil, you have to get a different model, and use another sensor for DHW.
Check your oil usage with that tankless coil. I have one, and I quit using it. It used about 2 gal. of oil a day in the summer.
A guy explained how the heat managers work a few months ago in this forum. If you search you may be able to find it. I didn't understand it.
It seems to me that it lowers the temperature at which your burner comes on, and you keep the high limit up at at least 180°. How it determines when to turn the burner on, I don't know, but it makes the effective differential in the aquastat larger... your burner runs longer and not as often.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
