Phase III with water under it on the floor
Wayco Wayne_2
Member Posts: 2,479
something similar and found a tiny leak on the threads of the Pressure relief valves. It wouldnt tighten enough to stop leaking, so I took it back out and wrapped several extra wraps of teflon tape and then used a hardening pipe thread sealant and let it harden overnight. S'all OK now but it was a little leak that was easy to over look. I used paper towels to dry the area and then to monitor it to find the leak. It ran down the inside of the tank and looked like something worse than it was at first. Hope this helps. WW
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=255&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
We have a Phase III hot water heater that uses boiler water to heat our DHW. I went downstairs today and noticed water under it on the basement floor (probably a quart or so). I felt the pipe that comes from the pressure relief valve, and it does not have any noticeable water on the end.
I then tested the relief valve (which is 150 psi and the appropraite btu/hr for our boiler), and it released water and then shut off completely. So thinking that the relief valve isn't bad, what other instances would cause there to be water on the floor? It doesn't smell like glycol (boiler water). We have a pressure gauge near the Phase III which reads 65 psi.
Thanks.
Dave0 -
When a Phase 3 leaks
it'll usually increase the water pressure in the boiler , which will pop the boiler relief valve . What is the boiler pressure ? Can you get a bucket under the boiler relief valve pipe ?
I've never seen a Phase 3 leak on the outside of the tank itself , but anything's possible .0
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 113 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 161 Indoor-Air Quality
- 70 Pipe Deterioration
- 994 Plumbing
- 6.3K Radiant Heating
- 391 Solar
- 15.4K Strictly Steam
- 55 Water Quality
- 44 Industry Classes
- 48 Job Opportunities
