Radiant Heating
Issac Weinstock
Member Posts: 2
The job is located in Monsey, NY. The specifications are as follows:
Heat source - Geothermal Technology.
Condensing boiler on site to be used as backup for heat.
Manifolds are divided at the two ends of the house.
Three floor temperatures:
Mostly wood which has 5/16" Viega installed Viega climate panel system (each loop at a max of 200').
Ceramic tiles which has 1/2" PEX oxygen barrier tubing (each loop at a max of 300').
Concrete, in basement, which also has 1/2" PEX tubing.
House has five full baths with showers, one of them including a shower with several jets.
6-8 people living in the house.
Please advise us with a piping diagram, pump sizing and electric controls.
Heat and hot water system should be controlled with outdoor reset and automatic mixing devices.
