Which pump is more efficient?
those head & flow requirements put this application out of the stratos' range, I believe the largest one they make (the 3 X 3-40) does 120gpm @ 40 ft of head
  • HydroMan
    HydroMan Member Posts: 14
    I'm looking for a circulating pump for a heating water system. Which pump is going to be more efficient:
    A.) Vertical multi-stage pump, 196 GPM @ 94'TDH, 7.5 HP, 75% pump efficiency, 3450 RPM
    B.) Vertical Inline pump, 196 GPM @ 94'TDH, 10HP, 64% pump efficiency, 1750 RPM
    Either pump will be controlled via a VFD.
    Thanks!
  • pump
    try the Wilo Stratos it is the most efficient pump on the market and you wont need the VFD it varies on its own. The rep here in Massachusetts is Sweeney Rogers in Taunton Ma.
