vent for single-pipe steam
tms_2
tms_2 Member Posts: 1
Hello, clueless layperson here trying to be proactive before fall...
I live on the 2nd floor of a brownstone with a single pipe steam system. First off, my heat levels are fine and consistent. However, my bedroom radiator's air vent blows steam (and eventually, a few drips of water) and hisses tremendously for as long as the heat is coming up (10-15 minutes at a time). I've read here that it could be a clogged vent. Unlike my living room radiator, the vent for this one is on the top, rather than halfway down, and appears to be of the Maid O Mist #72 variety--i.e. just a little stubby thing. Is this OK? Can I simply replace it with another of the same? I thought steam systems are supposed to have a float-style vent? The final factor is that the design of the radiator is such that no larger vent could screw in because it would be blocked by a 3/4 inch protrusion from the center of the radiator. Any thoughts on my best approach? Thanks!
