crane boiler rating
Steamhead (in transit)
Member Posts: 6,688
the National-U.S. Radiator Co. in the early 1960s or so. You might have a re-badged National or U.S. boiler.
The most likely candidate is the National 4-series. The 12-4 has an input rating of 619 MBH, EDR on steam 2060 (494,000 BTUH), EDR on water 3300 (495,000 BTUH).
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
crane boiler rating
I looked in the library in the beacon boiler books but
did not see any thing on crane 4-12 series B-4
large c.i. atmosperic. can anyone help?
thank you in advance.0 -
the b-4 large seems
to not be mentioned in my book..but i have a ''12 series Sunnyday Oil Fired'' which has a boiler #4-12 listed under it..its made by Crane..could that be the one your looking for?
old crane rating
this boiler is in a large 28 unit appartment.
what is the firing rate or water rating of your 4-12?
thank you
bob0 -
well that can't be the one then
cause its rated at 83500 btu...there is another boiler listed simply as ''crane #4 sectional oil fired'' and it has a 4-12 listed under it also..its rated at 3810 sq.ft. steam, 6095 sq.ft. water..does that one sound right? i'm looking in the ''hydronic rating handbook''by tom byrley.
crane reating
gerry
perfect, gives me a starting point.
thank you
bob0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
