Immersion type (low voltage) Hydronic controller
S R Denny
Member Posts: 26
I'm looking for an immersion type, low voltage, low temp hydronic controller. Watts and White Rodgers both have line voltage models and White Rodgers has a low voltage strap up model (1127-9). But, neither has an immersion type in low voltage. Any other possibilities you can think of?
Any.....
Honeywell 4006/6006 can be used with low voltage.
A controls are "break on temp rise only", but the C versions can do both, make on rise and break on rise.
They will only control 1 function though. If you're looking for more, I think any after market company make something to fit the bill.
Be prepared to have a few cups of coffee before trying to read their instruction manuals!(Boring doesn't even BEGIN to describe some of their summations!)
Tekmar,Taco and Uponor all share the same lines with different boxes and added functions. Be careful reading them. I've found the instructions to be the quickest cure for insomnia that I could ever find. Good luck. Chris0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
