Secondary pressure limit?
Home Depot Employee
Member Posts: 329
You would use the H/W L4079B1033 (2-15 PSI) which has a manual reset.
I would set at about 7-8 PSI, which is under relief valve setting to prevent nuisance tripping if boiler surges or partially floods.
My steam boiler at home cycles between 1/2 and 2 PSI, which is at the bottom end of the Pressuretrol installed on it. It also has a 10 PSI relief valve . . . but no secondary overpressure switch to shut it down if the Pressuretrol fails. In an industrial setting, I don't think this would be allowed . . . or at least I wouldn't want it that way.
Should I install a secondary, manual-reset limit switch, maybe set at 3 or 4 PSI? If so, could somebody recommend a part number. I'm finding the on-line Honeywell catalog information to be a bit vague.
Thanks again!0 -
Perfect! Thanks!0 -
OK, now I have one - sort of.
Money is a little tight after all the major repairs I've done on my antique home this year, so I'm leaning toward saving myself a couple hundred bucks.
I got a couple of working Honewell PA404A Pressuretrols for $5 on eBay. They aren't manual reset, but they do operate in the 0-10 PSI range. I'm thinking I'll install one in conjunction with what I have, and just set it a little higher. Since it's not manual reset, I'll need to check it once in a while to make sure everything is working right, but it should give me that little extra measure of safety.
Am I nuts? Comments?0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
