boiler losing pressure
thayer
Member Posts: 2
i set expansion tank to 12 psi
i have an electric allied boiler that will drop its pressure to zero when not used for a day or so. I replaced auto feed, expansion tank, check valve. i closed off all zones to be sure no leak out there, still losing pressure. when boiler kicks back on small amount of water enters through auto feed- not much-pressure shoots back up to 12 psi and all is well..no water loss from boiler anywhere. whats going on? boiler runs great but this is confusing0 -
Hmmm
What's the air pressure in the expansion tank when the system is off, cold and the tank is empty?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
