Honeywell Trolatemp and high static
Call Honeywell's Zoning Tech Support at 1 800 828 8367. Trolatemp no longer exists, it has been replaced by TrueZone, but the dampers are the same.
I have a standard ARD damper
in a zone system that runs at about 1.2" static. the high pressure is only at one damper that is close to the machine. The system runs at this pressure because the trunk duct in the wall is to small. It only feeds the second zone though. The high pressure on the first zone holds the damper closed some times. I know that California economizer makes high static dampers but I have had bad luck with them in the past and don't want to use them if I don't have to. I have a Honeywell MARD damper that is power open and closed. I looked all over Honeywell's site to see if it will handle higher static but found nothing spacific.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
