anybody know Lennox ?
Have a job to check out on installing a Lennox boiler.. Pvc intake and outlet.. This customer got it thru foreclosure deal and want it installed on his new radiant system. Checked the load rating and its aceptable.. Now im wondering the boiler been "rebranded" as its the first I seen here in this part of midwest... any postive or neggies on this bolier? Thanks for ur inputs.. Esp Brad, I welcome his wisdom....
  • Ross_7
    Ross_7 Member Posts: 577
    Lennox
    Hi Rj,
    Lennox boilers are in fact Dunkirk boilers re-badged. Lennox's residential website, should have all the info you need. If not, check out Dunkirk's website. I think that you're talking about a Quantum boiler (Dunkirk) if it's vented in CPVC/PVC. Good luck!
    Ross
