oil tank
rene_3
Member Posts: 21
I have a friend who has a raised ranch with a garage in the basement. The garage is where the oil tank is. The furnace is in a mud room just off the garage. The original owners had the tank installed and the bottom of the tank is around 3' off the floor. No one will fill his tank except the original oil supply company who's been doing it for years before he purchased the home. Is there any reason as to why the tank would be so high? He wants to drop it down to make it easier for them to fill and maybe run a fill pipe outside thereby he can shop around for other oil suppliers.
The oil burner that the tank originally sullpied was likely a gravity fed burner. Old old stuff. The tank needed to be higher than the burner so the oil can be drained out.
If the tank has long long legs like that it means its pretty old. It would be wise to replace the tank rather than simply lowering it. I would suggest a ROTH http://www.roth-usa.com/usa/Pfueltank-a.cfm
Good luckThere was an error rendering this rich post.
Is there anything in Code that requires the fill to be located outside?0 -
Yes
both fill and vent must terminate outside building
fill & vent
And the vent must be visible from the fill location.
If the tank is old, I also suggest a replacing it with a Roth.Hydronics inspired homeowner with self-designed high efficiency low temperature baseboard system and professionally installed mod-con boiler with indirect DHW. My system design thread: http://forum.heatinghelp.com/discussion/154385
System Photo: https://us.v-cdn.net/5021738/uploads/FileUpload/79/451e1f19a1e5b345e0951fbe1ff6ca.jpg0
- 167 Indoor-Air Quality
