quietside qvm info
Tim_41
Member Posts: 153
Have never seen one working or installed. I have seen many that were removed and sitting on the floor of the supply house.
anyone know anything about the quiet side qvm series wallhung condensing boiler/domestic water heter?Iam told they they only put out aprox 160 water that is adjustable wich would be a decent unit for radiant. I am just a little unshure about quoting to customers.0 -
RUN AWAY
I bought one once. Compleate crap. The instructions were horible the machine is poorly designed. Just imagine if you could go to the doller store and get a boiler.0 -
I'm seeing complete failure's in the five year range. A jillion o-rings and washers that all leak. Plastic fittings that crack with the heat. Exaggerated recovery and output. Parts are hard to find...unless the rep gives you a full set of parts for seed stock. The east coast rep just bought tens years supply of parts 'cuz Korea is gonna quit making them. The books are in broken engrish. Did I leave anything out...nope, I think I covered it.
Good news is that the Knight fits in the same spot.
Buy a real boiler.
Thank you, it sounds like a total piece of crap i will never install one.0 -
I have one in a guest house
The one and only that we installed. My fingers are crossed. It has been two years without a problem. My time will come and with it weeping and gnashing of teeth.0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
