Keeping old steam radiators if we are are switching hot water
john_210
Member Posts: 1
Hi All.
My wife and I have a 1910 Victorian home with steam heat and oil fuel-that is sky rocketing. We are looking to switch to gas/hot water heat and two contractors say the best efficiency comes from replacing the old radiators with these modern-looking metal squares things. Uchhh. We've been directed to this listserve for feedback and alternantive ideas. That is, would it be that inefficient to switch to hot water and keep the radiators? Is that possible. Are there other radiators or new fangled radiators that would be more in the tradition of hour home? Any feedback, direction, or information would be greatly appreciated. Thanks.
John
John
rust from old radiators may wear out pump quickly in new water system0 -
Fix the steam
if you have an old boiler, a new steamer will be much more efficient. Also, the system itself may need some work, but it's much less involved and more cost-effective than a disruptive, messy, expensive tear-out and replacement, and can produce surprisingly good efficiency.
Tell us more about your system- how many pipes are connected to each radiator- one or two? What type of boiler is in there now?
Also, where are you located?
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
