How do you label your PEX tubing ends?
JohnNY
JohnNY Member Posts: 3,341
What is that machine called?
Thanks for all suggestions!
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=290&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
  • JohnNY
    Labels
    Sharpees wear off. Tie-ons loosen and fall off.
    What works?
    Classes
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    I like ....
    Red tape on the feeds, and blue tape on the returns with a number written in sharpie, or roman numerals in black pen.
    I feel your pain after having to blow through numerous tubes to find the ones that the guys ran and never even attempted to label. (We'll find all that later!) Painters tape is easily removed and seems to hold up well. I have the choice of many colors at my local hardware store.
    I also got one of those Brother labeling machines.(Thanks Milne!) and I use it for everything I can. The labels hold up pretty well and look professional on legends too! Chris
  • klaus
    klaus Member Posts: 183
    Tape
    I do similar to Chris but with colored electricians tape. Rather than a Sharpie or pen I just wrap that many "bands" around the end of the tubing. Color coded and nothing to wear off. Also removes easily later if necessary.
  • Norm Harvey
    Norm Harvey Member Posts: 684
    The same label machine that prints labels for electrical wire you can feed a little extra out to accomodate the larger diameter of the pex before you cut the label. It's classy
  • Simply Rad_4
    Simply Rad_4 Member Posts: 4
    sharpie and cleaar tape
    we have been using a sharpie the cover it and the end of the tube with clear tape
    Jeffrey
  • Ed Lentz_2
    Ed Lentz_2 Member Posts: 158
    I put in phone systems for a living and we need to label wire for networks. We use a PTouch labeler. They have a TZ tape that has very strong adhesive, and a label that is 1" wide that is made to wrap around wire or any other round surface. The tape is laminated with a tough UV resistant covering. It would work great for labeling PEX. Just my $.002
  • Ed Lentz_2
    The labeler I use is a Brother P-Touch model PT1400. The tapes are the TZ version. The tapes can be gotten at ptouchdirect.com At that site you can get alot of info on the various types of tape for their labeling systems.
  • Tim Doran_4
    Tim Doran_4 Member Posts: 138
    Manifolds First
    We always(almost) set the manifolds first and hook up as we go. We then label each pair as they get connected and include the loop lenght for future balancing.
    Tim D.
