Mixing valve for floor loops
michael_34
michael_34 Member Posts: 304
So the cold return from the floor loop can temper the hot water enough to mix back into the floor loop? Great!
  • michael_34
    mixing valve for floor loops
    My boss just posed a question to me. He wants to know if anyone uses the cold return of the floor loop to feed back into the same mixing valve that feeds the floor loop? Instead of bringing CWS to the mixing valve for the floor loop.
    and if not why. advantages disadvantages.
    Thank you.
    Michael
  • Rich L.
    Rich L. Member Posts: 414
    Yes
    If I understand your question correctly, that is how we do it when doing a simple system with a 3 way mixing valve.
