3 pass oil boilers
Robert O'Brien
Member Posts: 3,592
think there's a bad triple pass oil on the market.Couple it with ODR and you're good to go!
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=313&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Anone seen
or tried the new 3 pass oil boilers from Utica / Dunkirk?
Comments? thoughts?
thanks0 -
Seen it and Put 2 Quotes Out
I had the chance to check out the Utica Tri-Fire and speak with our rep. Awesome unit, similar to the Burnham MPO. It even can be ordered with the supply manifold, like the MPO. Also has plenty of plug and play options. You can even plug in a secondary high limit, which I thought was pretty cool. It's a good way to get a client into the mid-80's as far as efficiency goes, especially in these tough times.There was an error rendering this rich post.
- 120 Geothermal
- 394 Solar
