advantages of gas vs. oil in a steam heat boiler system?
saussyHen
Member Posts: 19
We have a five story 120 year old brownstone that has oil heat and steam system. Strong fumes from old boiler come from chimney bothering owners of roof garden apt. Would a new oil burning furnace correct this or should we switch to gas? If the latter is the only option--are there problems switching if we're only replacing boiler and installing gas lines but not replacing steam pipes, radiators, etc.
Thank you for your input.
Patty
Patty
Your chimney needs to have a ss liner put in it. If you put in gas they will make you reline the chimney with a liner. Call a chimney Co. and get an idea of job costs. Everything in life comes down to one question and that is how much do I want to pay? The folks on the top floor may pay with their life.
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
