radiant baseboard
Home Depot Employee
Member Posts: 329
More baseboard and run at lower temps or use enclosure only
radiant baseboard
I'm considering running radiant baseboard, Slantfin probably, in a shop where the walls are already sheathed. So the baseboard and tubing will have to run along the surface of each wall. I'm wondering if anybody out there has a slick way of concealing/insulating the supply and return piping that runs before and after each baseboard. Or maybe I should skip the baseboard altogether and hang some air handlers? Ideas?0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
