DHW tank for boiler i.e. amtrol boilmate
michael_34
Member Posts: 304
I have used those and still will, I really like the idea of keeping the solar hot water moving. That way in the solar tank there is better stratification. Move the heat to be used for DHW to a smaller tank and leave some more room for more solar. Very common practice.
I'm looking for a more cost affective DHW tank than the Amtrol boiler mate. I use the 26 gallon (WH-9 series) to tie into my solar tank in a pre-existing DHW system. Any suggestions. I am paying around 900.00 for the Amtrol.
Many Thanks,
Michael0 -
Buderus S-120
This is a very good tank and cost is better than the one you mentioned
David0 -
perfect
Hey that is perfect! The high temp limit in going from the boiler on the Amtrol is only 150*. The Buderus is 203*, which is great for solar! Thanks Michael
Why ?
not just use a solar designed double coil tank?
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Michael,
The boiler mate has a coil assembly that is very restrictive and prone to scale up.0 -
Michael,
Since this computer has a tendency to double posts I will add that I had a boiler-mate years ago for a wood system and while it was one of the pioneers of domestic indirect
DHW there are better options now.0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 975 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
