Flat plate heat exchanger
Tom Hopkins
Tom Hopkins Member Posts: 554
Thanks Hot Rod. This is what I thought.
  • Tom Hopkins
    Just want to know if there is a possibility of damaging a flat plate heat exchanger when only one pump is running. That is, the input pump circulates while the output is stopped.
    Thanks,
    Luc
    hot_rod Member Posts: 27,344
    fluid on both sides?
    what kind of operating temperatures?
    hr
  • Tom Hopkins
    It is between 140F and 180F on the input side. There is a glycol solution on the output side.
    Luc
    I don't
    see a problem, check with the manufacturer to be certain. If it is a brazed plate HX it is assembled under much higher temperatures.
    180F is not too high to stress the glycol, either.
    hr
  • Tom Hopkins
    Thanks hot rod. I thought the same thing but I wanted to check out with someone on the Wall.
    Also, I just want to say that I appreciate your articles in Phc News. I am looking forward to your future webcast on solar radiant.
    Regards,
    Luc
    It may thermo siphon
    also, on the "off" pump side. Unless you have good check valve or flow check protection.
    hr
