radiant wall detail for basement
rb_6
Member Posts: 222
Basement reno photo's of heated wainscotting.
Basic Wall detail
Grade>Concrete wall>1.5" Dow sm>2 x 4 batt insulated wall(bottom plates wrapped in poly)>
plywood for wainscotting fastners>Uponor's QuickTrac >Drywall>Schluter Water Proofing>Wainscotting>baseboard
Should have the project done by July/August...just in time for my eldest to move in for the next few years of college.
Basic Wall detail
radiant wall detail
I was hoping to incorporate radiant plates behind a wainscotting detail in a basement playroom. The detail will have a finished height of 42" and the plates would be attached between furring directly on wall studs(2x3 on edge) with foil-faced polyisocyanurate insulation directly behind studs. Is this a decent design or is the insulation too far from the plates to be effective? Any thoughts would be appreciated. Thanks!0
- 87.5K THE MAIN WALL
- 123 Chimneys & Flues
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
