BOILER QUESTION
Brad White
Member Posts: 2,399
add up to about 40.5 EDR each and 202.5 in total. At 170F average water temperature that is 30,375 BTUH, well within range for that boiler if my math is right.
What is the space heat loss?
It appears that your radiation and boiler are existing "givens", so the heat loss will establish your highest required water temperature.
Is this controlled with outdoor reset that might limit the HWS temperature?
Are the radiators piped in series or in parallel?
-Ernie White, my Dad
BOILER SIZE AND HEATING SUNRADE RADIATORS
HAVE A BUNAHAM 203 GAS BOILER WANT TO HEAT 5 18 SECTION
SUNRAD RADIATORS, SYSTEM IS PIPED 3/4" PEX DIRECT PIPING,
BOILER WILL NOT COME UP TO 180 DEG. TRIED BYPASS PIPING.
TAKES ABOUT 30 MIN. TO GET TO 130 DEG. ALSO ABOUT 100 FT.
OF PIPING TO AND FROM RADIATORS. WOULD MOMO FLOW PIPING HELP, BIGGER BOILER?
ANY HELP THANKS0 -
start again....
Do a heatloss, then size the radiation and figure the boiler ....0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
