gas steam-efficent?
Al Letellier_9
Member Posts: 929
Yes it can and yes they do. My favortie steamer is the Weil McLain SGO boiler and it can be fired with either oil or gas. With a Riello burner, either can fire at relatively high efficiencies. Have done a lot of these and one has been converted 3 times already.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=522&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Gas steam boiler-efficient?
I know that the heat from an oil fired boiler is hotter so can gas steam boilers be as efficient?
Is there such a thing that a boiler that can be converted from gas back to oil or are the designs too restrictive for that to work well?0 -
Another good choice
is the Smith 8 series. It is available from the factory with Beckett, Carlin and Riello oil burners as well as Carlin's EZ-Gas power gas burner (called the G-8 when so equipped). This means it comes with full factory certification and warranty. Here are a couple of G-8 installation pics we've done.
BTW Al- last I heard W-M did not offer gas burners for the GO series from the factory. Has this changed?
- 87.5K THE MAIN WALL
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
