Proper size brush to clean WM SGO-4
J.C.A._3
Member Posts: 2,981
Milrose 84200. I wish the handles were a bit thicker,but they clear the pins fairly well. I also like to follow up with the softer "tapered" slightly lighter bristled brush.Go from both directions,and alway follow up with a soot saw to get the ends that can't be reached because of the tilt of the pin pattern
Between the 3, you should have a pretty clean set of pins. Hope that helped. Chris
What size brush is best for cleaning the heat exchanger of the SGO boilers?Steve from Denver, CO0 -
I see the 84200 on the Millrose web site. It's a 1-1/2" x 1-18" brush.
They also show a 84201 horsehair brush. Is that what you are referring to? I'm not sure what brushes are tapered.
SteveSteve from Denver, CO0 -
I think....
It's the 82215 that I use. At 30" it's a bit longer than the round brush, but makes the touch up quite nice. Chris0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 27 Recall Announcements
