standerd fittings used in hydrolic systems
Big Will
Member Posts: 395
I have a job coming up next week. We need to move a large boiler away from the wall. I bought two hydraulic rams and a pump to push it with. cheap and easy right? I needed 1/4 X3/8 inch bushings to assemble the hoses. while tightening the fitting it exploded. I had filled the hose with fluid before assembly to reduce the amount of air I would need to purge. When I tightened the fitting the pressure must have become very high because the bushing just exploded and shot across the shop. After changing my shorts I got to thinking. Was that just a bad fitting or are regular pipe fitting to week to cary hydraulic pressure?
explosive pressure
i think the pressure of hydraulic systems can be be much higher than the 150 psi most plumbing fittings are rated for--such as 1000 psi.
your experience is similar to those of people changing their steam systems to hot water--nbc0
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 107 Geothermal
- 70 Pipe Deterioration
- 983 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
