Antifreeze ffer tank for boiler
The Axiom website is www.axiomind.com.
Antifreeze buffer tank
About 4 years ago at a trade show I saw a 2 chamberd tank "like a Extrol tank" tht was for adding antifreeze to a system that kept constant pressure on it through the water feeder. it kept make-up water isolated from the system via a diaphram in the tank and antifreeze in the other chamber that the water pushed against. does anyone know who made this? Iwant to use one but can't find it.
Hey Scott,
I've used a product that is made by Axiom.
I found a cut sheet for it at Capco supply's web site...under hydronic specialties (capcosupply.com). I think it's what you want.. Chris0 -
Thanks Chris, That is not what I sw but this unit you showed is much better due to the fact there is no water available in this remote building. Thanks for the help
No problem Scott.....
What are friends for?
I've used a couple of these units with 0 problems. With no makeup water available...make sure you have some low water protection! Glad to help....Chris0 -
I think i know what you are referring too. i have seen it at a show a while back. here is a link to the manufacturer site. http://tekforceproducts.com/glycolexpressjr.html
let me know if it helps.
- 114 Geothermal
