Hot water loop
Larry Weingarten
Larry Weingarten Member Posts: 4,010
This site is frequented by many of the most knowledgeable hydronics technicians in our solar system! Maybe if your question asked about design and gave a better idea what the constraints were, you would get a better response.
Yours, Larry
  • Mark S_2
    Mark S_2 Member Posts: 1
    Hot Water Loop
    I have seen a single loop systems run off the homes hot water tanks. To heat a single room or area that doesn't get heated enough. Is there a company that sells these kits or some place I can get a diagram and a list of parts needed to accomplish this ?
