Bench Mount Copper Tube Bender
bob_46
bob_46 Member Posts: 813
Parker-Hannifin (spell) makes a bench mount hand cranked bender. It bends 1" SS with no problem, one hand is all you need. bob
  • Josh M.
    Josh M. Member Posts: 359
    Anybody know of a good bench mount copper tube bender that has a capacity of 1 1/8" O.D.? Actually larger would be good too.
  • bob young
    bob young Member Posts: 2,177
    HOT ROD
    You gots to talk to HOT ROD.....Greatest pipe bender that ever lived.
    hot_rod Member Posts: 25,225
    do you mean hand operated or powered?
    the REMS Curvo has a tripod option, I'm sure it could be bench mounted.
    Remember if you want to bend 20 foot lengths you will need some "swing" room or the bender will need to swivel on it's mount.
    My REMS will bend up to 1-1/4 copper. I believe they now have a 2" model??
    I have heard of guys bending copper with an electrical condiut bender. I've never had good luck with one on hard drawn copper.
    It takes some power to bend 1-1/4 copper. I'm not sure a hand bender would work without a 10 foot handle :)
    hr
    hand or electric powered?
    It would be a pretty tough go to bend 1-1/4 copper with a hand bender. it takes some power. maybe with a 10 foot handle :)
    The REMS has a tripod option. I'm sure it could adapt to a bench mount easily.
    I think REMS now has a model to bend up to 2" copper?
    hr
  • bob young
    beth. steel & gen. dynamics
    IF you ever saw the bending apparatus we used in the shipyards you would be in heaven, hot rod. and this was in the sixties. any size , any flavor !!
  • TONY_22
    TONY_22 Member Posts: 28
    Ridgid
    Used to make several size pipe benders built into their 'tri-stand' pipe vise.Also "Greenlee" has a wide variety of benders for electricians.
    Ridgid Model 460 Tri-stand has 3 different pipe benders built in
    Rich
