Tankless boiler Q
Bruce M_2
Member Posts: 123
I would suggest a gas fired om-demand water heater such as a Navien.
I just bought a 2fm house that has a oil fired one pipe steam boiler for the rental unit. The boiler also provides domestic hot water ie a tankless water heater. The boiler is about 30yrs old.
I think this set up is a scam by the oil company's to get people to burn oil year round. I would like to connect a separate hot water heater so the boiler is not called on during the summer.
The Q is would it be better to do a superstor indirect water heater tied into the boiler OR get a gas water heater that has it's cold water supply come thru the boiler first thus getting a little 'free heat' boost when the boiler is running in the winter.0 -
Some scam
I could give you the answer but I also sell oil so it would just look like another scam. 30 years ago oil was probably about 30 cents a gallon so what was economical then is not economical now.
Ken
Scam?
What scam? Customers have all too often chosen to go with a tankless because the upfront cost was cheaper. They never looked down the road at the continuing costs to maintain hot water. To answer your question go with the indirect. If a boiler maintained heat for 30 years cooling it down can cause leaks, an indirect will add heat periodically. As an oil company worker I wouldn't want to work for you, you would distrust me before I even entered your basement.
Leo0 -
I did not mean to imply that oil guys are scam artist. It just that having a whole house boiler turn on just to wash some dishes is excessive. In would be like using a Kenworth to go to the corner store to pick up some bread.0 -
The Kenworth
is probably more efficient than a Hummer on a lb/mile basis. A heating appliance should be chosen according to the job it is expected to perform.
Ron0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
