fireplace inserts
With my Jotul wood stove insert. Get one that has a connection for outside air, it makes a huge difference, but every one will tell you it won't make much difference. You will probably need to get your flue lined also. You will save a lot of money on your heating bill and you will have a really warm spot in the house to get the chill out of your bones.
Thanks, Bob Gagnon
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=331&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • realolman
    realolman Member Posts: 513
    anybody
    have any opinions or recomendations on fireplace inserts.
    I have a nice masonry fireplace. Although it does make some heat, we just burned it cause it's nice. I don't think we've been all that interested in getting much heat out of it.
    I think that attitude is changed.
    We'd like to burn it with the doors open with a screen when we're in the room, but shut the door when we're done or when we're not sitting there. I saw one on the internet that would do that, but I haven't been able to find it again.
    Any opinions, recommendations, or experiences would be appreciated.
  • Bob Harper
    Bob Harper Member Posts: 1,151
    heat vs. aesthetics
    Those are your choices. If you want looks, get a vented gas log set that requires the damper be removed or blocked wide open. If you want heat, you will need a sealed combustion direct vent, which means the glass stays on.
    I recommend HHT inserts but most brands are good quality. You can start here: www.fireplaces.com
    HTH,
    Bob
  • realolman
    Thanks... I'm looking for a wood burning insert, though.
  • Evan David
    Evan David Member Posts: 2
    Fireplace Insert...
    Before you go for an insert check out your options for retrofitting a Rumford fireplace. Here's a website: http://www.rumford.com/
    You'd be amazed at how efficient these can be.
    Best of luck.
    Evan
