Best Temp Valve
Metro Man
Metro Man Member Posts: 220
We have used Taco's, Caleffi's, Oventrop's, Watts, and some others and just wanted opinions what other pro's are using. Our application is usually off of dhw to house taps. But will sometimes need to go from solar dhw to dhw to protect dhw tank.
Issues we have is that the solar dhw temp will obviously fluctuated considerably causing variances in the hot out of temp valve. We always install w/spring check and iso. valve on cold inlet.
Thanks for input and have a great Labor Day.
Metro Man
