heat balancing
matt boulay
Member Posts: 2
Anyone know of an easy way to balance a system with both baseboard and cast iron radiators?
living room baseboard
bedroom baseboard
dining room baseboard
kitchen radiator
bathroom radiator
I'm currently converting from old one pipe steam system to a new forced hot water system with baseboards, but due to current configuration of house, space is limited. Long term plan is to remodel house and change radiators to baseboard, but there is no space for baseboards in kitchen and bathroom for now. I need a low cost method of balancing heat. I haven't installed anything yet. Currently the whole house is radiators. Any ideas?
bedroom baseboard
kitchen radiator
bathroom radiator
heat balancing
bedroom baseboard
kitchen radiator
bathroom radiator
I'm currently converting from old one pipe steam system to a new forced hot water system with baseboards, but due to current configuration of house, space is limited. Long term plan is to remodel house and change radiators to baseboard, but there is no space for baseboards in kitchen and bathroom for now. I need a low cost method of balancing heat. I haven't installed anything yet. Currently the whole house is radiators. Any ideas?0 -
Yes
Keep the steam. Whatever problems you have with the current system can be fixed for far less than you'll spend on a tear-out/complete replacement job. And once fixed, your current system will be about as efficient as hot-water.
Your plan might not work for another reason: there are quite a few old radiators that will not work on hot-water... only steam.
Zone it
If it is to late to keep the steam then make the kitchen and bath a seperate zone. Radiators get hot and hold the heat a long time , baseboard heats up and cools down quicker. They don't play together well.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 27 Recall Announcements
